How to terminate AzureEventHubsConnector in receive stream mode?
  • Jul 19, 2023 2:42 PM UTC
  • 28 views
When using the AzureEventHubsCOnnector to receive in stream mode, the documentation states "Stream: The connector continues to receive messages indefinitely. The translation needs to be terminated in order to stop reception." Am i missing something here? how do you send a termination to it? In python this is straightforward...
danminneyatsaf
Forum|alt.badge.img+13
Hi @paul.brignall​, this could be done by manually stopping the workspace OR by using the Terminator transformer. You could use a Tester transformer, and if any features fail the test logic you've set, it would then go to the Terminator which stops the workspace from running.
