Hi all,
I'm trying to use the AmazonAthenaConnector but I'm not sure what the correct settings are.
Firstly, what do I need to put in the Bucket / Path fields?
Secondly - when I try adding values in these field and run the translation I'm getting the following error:
Invalid bucket name "all-product-athena-result/": Bucket name must match the regex "^[a-zA-Z0-9.\\-_]{1,255}$"
Error encountered while calling method `input'
AmazonAthenaConnector_2_CALLER (PythonFactory): PythonFactory failed to process feature
Thanks,
Ed
