How to remove elevation from BIM file?
oscard
Forum|alt.badge.img+22
Good morning.
I'm putting together a workspace to transform a Revit file into Cesium 3D tiles. Overall, it is a pretty straightforward process, but I'm facing an issue with the elevation.
The building stored in the Cesium 3D tiles is floating, so I need to offset the Z to put it in floor level over a 2D basemap. I've been using the Offsetter transformer with lots of trial and errors until getting it right, but I would like to know if there is a better way.
So the question is: Is it possible with FME to make that "elevation removal" automatic?
Best answer by chrisatsafe
Hi @oscard​ ,
If you have floating features you can use an ElevationExtractor (1 in the image)or BoundsExtractor (2 in the image) to get the z value, then set the Offset Z value to negative @Value(_elevation) or @Value(_zmin). This extract the elevation to an attribute (either _elevation or _zmin depending on the transformer you use) which can then be used to offset in the Offsetter. 2021-02-02_14-13-54
chrisatsafe
  • February 2, 2021
Hi @oscard​ ,
oscard
  • February 3, 2021
chrisatsafe wrote:
Hi @oscard​ ,
Hi! Thanks for the answer!
That worked.
I have to aggregate the geometries first and then apply the ElevationExtractor, otherwise all the buildings floors are pushed to the ground.
