How to READ and WRITW *.PTS / *.E57 file format >>>>>> *.PTS in FME 2022.2 version ?
  • Mar 16, 2026 3:57 PM UTC
  • 100 views
vimalvaghani
Forum|alt.badge.img+3
Hello I have FME 2022.2 version and i also could upgrade it to 2025 if it helps but i would like to extract data
Input data : *.pts or *.e57 file format (about 2 to 5 room point cloud data in One *.pts file/*.e57file)
Desired output data : *.pts file format (ONLY 1 room to be extracted in *.pts file format)
Other supporting data : Sitewide room model in *.ifc format (federated model having about 20+ rooms in 1 IFC format)
TASK : Using IFC room model for any give Room for example (Room1), i would like to clip the input data set i.e. in *.pts/*.e57 file format and out only that particular room  (Room1) *.pts format data.
Am not sure how to set / which reader and writer / transformer to use to get it right . I understand i will have to use Clipper to clip *.pts file using IFC file somewhere.
Highly appreciate and obliged with workflow for your support and know-how.
vimva679
Forum|alt.badge.img+11
  • Mar 17, 2026 1:52 PM UTC
​@daveatsafe Any Idea Dave ?
max_h
Forum|alt.badge.img+39
  • Mar 18, 2026 2:48 PM UTC
​@vimva679 ‘s workflow from two years ago should do the trick: IFC 3D Room Clip and Buffer | Community
Can you rebuild that one and report if you get any issues?
