IFC 3D Room Clip and Buffer
  • Feb 26, 2024 5:04 PM UTC
  • 75 views
vimva679
Forum|alt.badge.img+11
I have IFC file with 3D Room and Excel Records with XYZ and i am trying to clip the XYZ coordinates that totally fall or touch the boundaries of 3D Room.
I would like to confirm is that,  i am following the right steps in Workbench ?
I would like to ADD 10 cm buffer to 3D rooms, so that i don’t miss any XYZ records, so not sure what is equivalent value as there is UNIT in buffer :( Also i would like the EDGES to be SHARP after applying buffer not sure how to do
PS: Attached is FME Workbench for further reference, as its does work if anyone would like to refer as well. But open for any enhancement as well.
evieatsafe
Forum|alt.badge.img+28
  • Mar 19, 2024 9:02 PM UTC
Hi @vimva679 I think this is a good workflow. Just for your reference as well, if any transformer does not provide a parameter for the unit then it is the unit of your data or coordinate system. You can view the coordinate system information in the Feature Information window.
