How to find unnecessary network (line)
Dear Sir / Madam,
I have an indoor data set. As shown in the figure below.
Red line represents network path.
Blue circle is the POI (Point).
Black dot is just the vertex.
As I have an indoor data for the entire building. I would like to find network that is unnecessary (not linked with any POI), as shown as Yellow Circle.
I am just wondering what transformers I can use to find these path?
I cannot just simply break the lines as some vertex are necessary for turning.
I would really need some hand.
Thank you very much!
Best answer by geomancer
Look into the ShortestpathFinder. This transformer uses the network (which you already have) and From-To lines connecting every pair of POI.
There are many ways to create those From-To lines. An easy way is to create lines between all POI, and keep only the lines going from a POI_ID to a higher POI_ID.
The segments that you are interested in exit the ShortestpathFinder from the Unused port.
ShortestPathFinder
geomancer
Forum|alt.badge.img+56
  • April 25, 2023
ShortestPathFinder
  • April 25, 2023
The NetworkTopologyCalculator might be a starting point.
ShortestPathFinder
@geomancer​ Thank you soooooooooooo much for your detailed workspace, it helps a lot!!! As I have no clue where to start.
However, I tried to modify a little bit, since I have to do this on each floor. At the end, the shortestpathfinder transformer couldn't find the path for 2nd floor POI D to E and POI E to F and go to "NoPath". Might I ask what's wrong with my transformer? I have attached my new data and fmw below. I hope you can have some spare time to solve my problem.
Also, I have other questions, what is the purpose for TestFilter. (@Value POI_from < @Value POI)?
Sorry I have asked so many questions.
Again, I am really appreciated your help!
geomancer
  • April 26, 2023
ShortestPathFinder
Hi @zacharylee_1204​ , I am glad I can help you! Your lines on floor 2 are not split at the junctions.
Problematic_LineYou can remedy this with a Chopper in mode 'By Vertex', setting the maximum number of vertices to 2.
TestFilter. (@Value POI_from < @Value POI) reduces the number of lines between the POI. The workflow creates line A-B and line B-A, but you only need one of these lines. The workflow also creates 'line' A-A, which is also not needed.
It works!!!!!!!!!!! thank you so much @geomancer​ .
Actually I have already break the lines by using "Intersector", but I am not sure why it doesn't work.
So (@Value POI_from < @Value POI) means it comparing the value? As you said, if it has line A-B and B-A, so B-A is larger than A-B?
I am kind of confused. Sorry about that ^^"
Anyhow, I am really appreciated your help. It works! YEAH!!!!!!!!!!!!!!!
geomancer
  • April 26, 2023
Good to know this works 😀
The TestFilter compares the value of attribute 'POI_From' with the value of attribute 'POI'. Only when the value of 'POI_from' is smaller than the value of 'POI', the feature passes the test.
POI_From | POI |  result
    A    |  A  |  fails
    A    |  B  |  passes    --->
    A    |  C  |  passes    --->
    B    |  A  |  fails
    B    |  B  |  fails
    B    |  C  |  passes    --->
    C    |  A  |  fails
    C    |  B  |  fails
    C    |  C  |  fails
Got it! Thank you so much! You are awesome! :)
geomancer
  • May 8, 2023
This can also be done using a NeighborFinder in Candidates Only mode, instead of the FeatureMerger (see this post for an example).
