How to find letters after a period using regex and capitalize the first letter?
leida
Observer
I tried to find letter after period and capitalize it using StringReplacer but it did not work. Is it possible to accomplish such a thing with the StringReplacer? For example: Condition: good. ensure continuous maintenance. The result should be like this: Condition: good. Ensure continuous maintenance.
Text to Replace: (^[a]|\. [a-z])
Replacement txt: .\U$1 also \U\1 won’t work.
Thanks
Leida
Best answer by joepk
Hi Leida, I haven't got the /U$1 approach to work either. I used a StringSearcher to get the first letter after a period in an attribute (with RegEx: (?<=\. )[a-z]), and a StringConcatenator switched to Advanced mode with the following Expression:
@ReplaceRegularExpression(@Value(test),(?<=\. )[a-z],@UpperCase(@Value(_first_match)))
Notice the same RegEx in the String Expression.
Hope this helps!
joepk
Forum|alt.badge.img+20
  • March 25, 2024
Hope this helps!
danilo_fme
Forum|alt.badge.img+51
  • March 25, 2024
Hope this helps!
Great
geomancer
Forum|alt.badge.img+56
  • March 26, 2024
It appears \1 cannot be modified.
Original Text Condition: good. ensure continuous maintenance.
Text To Replace (^[a]|\. [a-z])
Replacement Text xx@UpperCase(\1xx)
Results Condition: goodxx. eXXnsure continuous maintenance.
joepk
  • March 26, 2024
Nice find @geomancer, I also really can't seem to find a way to modify the result from \1.
Although using multiple transformers isn't that bad, this seems like it could be a nice addition to the string functions FME already has!
