How to expose attributes of a layer of CAD?
  • November 6, 2021
  • 169 views
aryalahasa04
Forum|alt.badge.img+5
Hi all!
My CAD layer is a mapimport from shapefile. So, it basically still has attributes when I converted to a layer with point type. When I wanted to export again to shapefile through FME, I don't know how to retain those attributes.
In CAD, actually you can use MAPEXPORT to retain attributes, but then it will be time-consuming if you need to export one by one when you have many.
So guys, do you have a solution for me to solve this problem? Thanks in advance!
danilo_fme
Forum|alt.badge.img+45
  • November 7, 2021
Hi @aryalahasa04​
What kind of attributes that you want to expose?
Thanks in Advance,
Danilo
aryalahasa04
  • November 15, 2021
danilo_fme wrote:
Hi @aryalahasa04​
Thanks in Advance,
Danilo
Hi @danilo_fme​ , Thank you for your response!
image.pngAttributes like in the picture above. I'd like to retain all of them in .shp format again.
nielsgerrits
Forum|alt.badge.img+55
I don't have a sample file to test, but I think if you use the "Autodesk AutoCAD Map 3D Object Data" reader it will just read the attributes, as it is Object Data.
