How to expose a File Geodatabase Domain
  • December 11, 2017
  • 469 views
I have a file geodatabase with a number of domains and I cannot work out how to expose the domain values.
I have ticked 'Resolve Domains' in the Reader Parameters and then exposed the attribute domain in the following way in the AttributeExposer transformer by typing: '_<attribute>_resolved_' based on the information I read in the following article:
https://knowledge.safe.com/articles/22897/working-with-geodatabase-domains.html
However the attribute I exposed is empty in the output file.
Can someone please assist?
Thank you in advance.
I am using FME 2017.0 32 Bit.
Actually I have worked out what the issue was myself!
I ticked 'Resolve Domains' after I had already added the feature class to the workspace by clicking on the feature reader parameters and then ticking the check box.
But what I needed to do is tick 'Resolve Domains' while I was first adding the feature class to the workspace. When I did this, the <attribute>_resolved attributes were added to the 'User Attributes' automatically.
