How to dissolve polygons only if there isn't an obstruction
  • August 5, 2018
  • 4 views
I have a set of touching polygons representing physical spaces and lines representing the doors on the polygon boundaries dividing the spaces. I want to dissolve only the polygons that aren't separated by a door. Not sure how to group the corresponding shapes. The doors are only a small segment of the boundary.
  • August 5, 2018
Could you please share a sample dataset including spaces (polygons) and doors (lines)?
