How to dissolve only certain polygons by using markers
  • Mar 6, 2018 11:44 AM UTC
  • 8 replies
  • 119 views
chau
Forum|alt.badge.img+8
I have a set of polygons which has been clipped at one point in time. I would like to dissolve them back together but only along the path originally used to clip them. I don't want to dissolve all polygons touching each other.
My approach so far has been to locate the edges of the polygons I would like to remove and I have marked those in the image below (I have the markings as features). I don't have a common ID on the polygons I would like to dissolve, so I haven't found a way to group the polygons to dissolve them in that way, since one polygon might have more than one marker attached.
How can I achieve what I have outlined below?
Reference:
  • Mar 6, 2018 12:37 PM UTC
If your polygons have a common ID that defines their original composition, you could use that as a Group By in the Dissolver.
chau
  • Mar 6, 2018 2:18 PM UTC
I forgot to mention that I don't have a common ID anymore :( What you see is what I have.
  • Mar 6, 2018 2:23 PM UTC
Do you have the red circles (I suppose that's what you mean by markings)? If yes, could you post a small sample dataset here?
chau
  • Mar 6, 2018 3:03 PM UTC
Its attached to the question.
gio
Forum|alt.badge.img+15
  • Mar 6, 2018 3:17 PM UTC
chau
Create id's for the circles.
Spatial relate with the objects.
Create a string from the list using a listconcatenator. (or query the list)
Compare lists and create a group id.
Use this group id to dissolve.
fmelizard
Forum|alt.badge.img+22
  • Mar 6, 2018 6:56 PM UTC
remove-intersecting-lines.fmw Hi @chau I would use a SpatialFilter to identify the lines to be removed and then rebuild the polygons.
nielsgerrits
Forum|alt.badge.img+67
Nice solution!
chau
  • Mar 7, 2018 9:16 AM UTC
Hi Dan, thank you for the very elegant solution - it works really nice!
