How to detect or by-pass self-intersecting poly boundary?
aguan
Forum|alt.badge.img+11
I have a workbench that generates polygons from points. It fails at one polygon since some of points for that polygon are self-intersecting. The error is " The error message from ArcObjects is: {Linestring or poly boundary is self-intersecting}". Is there a way to pre-test or filter those points?  I would hope to by-pass generating  this polygon and continue the run.
Allen
fmelizard
Forum|alt.badge.img+19
  • August 16, 2013
HI,
Assuming you are using FME 2013 the geometry validator can repair this type of errors.
aguan
  • August 16, 2013
I am using FME 2012. Look like I can use GeometryOGCValidator to filter out those points. Seems to me most of those self-intersecting errors were just tolerance issue and I have no problem create a polygon from them using ArcGIS desktop.
  • August 17, 2013
Hi Allen,
In my experiences, ArcGIS seems to be relatively lenient to self-intersections except when performing geoprocessing. So, if you need to perform some geoprocessings, I think you should check or repair geometries with an appropriate tool like FME or ArcToolbox beforehand.
Takashi
