How to convert Roman numerals to numbers?
  • May 28, 2019 2:47 PM UTC
  • 158 views
Hi!
I have a problem which I am not able to solve at the moment.
I have codes (as a string) including letters and roman numerals, in a style similar to this:
ABCDE IV-a
I would like to change this to:
ABCDE 4-a
I was able to split the string into parts, so that I have a new column with just the Roman numerals. But how do I change those roman numerals to numbers in FME?
Thank you!
  • May 28, 2019 2:49 PM UTC
It should be fairly easy to incorporate the following code sample into a PythonCaller:
https://www.oreilly.com/library/view/python-cookbook/0596001673/ch03s24.html
  • May 28, 2019 3:46 PM UTC
Here's a sample workspace (FME 2019) that demonstrates a possible solution: roman_numeral.fmwt
Assuming the input attribute code = ABCDE IV-a, the output is result = ABCDE 4-a
The regex in the StringSearcher assumes that the roman numeral will always be prefixed by a space and followed by a dash.
  • May 29, 2019 7:24 AM UTC
Thank you! That's really helpful!
gio
Forum|alt.badge.img+15
  • May 29, 2019 11:54 AM UTC
@volodya_17 @david_r
The python script posted is wrong, as there are rules in ROMAN..
In the posted script one can shamelessly enter VVVV as a roman, which is clearly not a roman number, and get 20 as result.
For instance IC is 99 according to the posted script, but this is not a roman number as XCIX = 99.
Max 3 consectutive of same numeral allowed. One numeral cannot be preceded by a numeral that is more than one level lower ( so XC is allowed but not IC). etc.
So you either respect  the rules for Roman numbers or should replace the string with
{1000 M 900 CM 500 D 400 CD 100 C 90 XC 50 L 40 XL 10 X 9 IX 5 V 4 IV 1 I}
and do some slight changes to the posted code.
I am wondering, you all do know this very awesome site? (if not you really should)
https://rosettacode.org
You see at that site several python  ways to do it.
But you also see, as fme has a R caller, that R has a function for it. How convenient is that?
Also you clearly see that TCL has a superior code...;)
Have fun and greets!
