How to concatenate a date field (format: mm/dd/yyyy) and a time field (format: hh:mm:ss) to a single field (format: mm/dd/yyyyhh:mm:ss)? They are already transformed by two separate AttributeManager.
  • Jun 16, 2023 5:10 PM UTC
  • 167 views
  • Jun 16, 2023 8:11 PM UTC
You can concatenate them as regular strings, e.g. in an AttributeManager:
@Value(my_date_attribute) @Value(my_time_attribute)
Thank you for answering. they are not strings. the formats are date and time and will be translated to DateTime.
hkingsbury
Forum|alt.badge.img+73
  • Jun 18, 2023 10:34 PM UTC
Thats fine, internally, FME treats datetimes as strings.
In fact datatypes really only exist when data is read/written - oversimplification, some more advanced use cases mean you need to change/specify data types within the process. In your case, datetimes in FME can just be treated as strings
