How to add vertices along line?
makt
I am looking to add vertices every X meters along a line (singlepart shapefile). Chopper seems to almost get me there, but it is making a multipart shapefile rather than working at a vertex level. Is modifying the abilities of the Chopper with another transformer the right approach?
Best answer by takashi
Combination of the IterativeSnipper_2013 (FME Store) and the LineJoiner could be also effective.
  • May 8, 2014
Hi, the Densifier might help you. Alternatively, you can also use LineJoiner to re-connect the chopped lines after the Chopper.
Takashi
  • May 8, 2014
makt
  • May 8, 2014
thanks Takashi - IternativeSnipper+LineJoiner worked.
somehow Chopper+LineJoiner did not do the trick (I think I tried this before). Any ideas as to why? Perhaps there is a specific setting needed in the menu that I didn't get.
  • May 8, 2014
The Chopper seems to divide a line at existing vertices, so there is a case where the length of chopped line is much different from specified Approximate Length.
makt
  • May 8, 2014
thanks for this clarification!
pratap
Forum|alt.badge.img+12
  • May 17, 2014
I suggest "Densifier"
