How do I overlay a set of lines/vectors on an image?
  • Nov 9, 2020 12:42 PM UTC
  • 142 views
How do I overlay a set of lines on an image? See below…. I cant see the lines on the image?
Capture
  • Nov 9, 2020 12:43 PM UTC
I would try the MapnikRasterizer. Just make sure that the vectors are on top of the raster.
  • Nov 9, 2020 12:45 PM UTC
How do you make sure the vectors are on top?
Forum|alt.badge.img+54
  • Nov 9, 2020 1:03 PM UTC
The ordering is controlled by the input ports on the Mapnik Rasterizer, with the top port being drawn first as the bottom most layer.
Probably a good idea to check that your raster and vector are in the same coordinate system also
  • Nov 9, 2020 2:26 PM UTC
Thank you. I've done the everything just not quite seeing the lines appear ontop of the rasta. It seems as if the lines are condensed together at the top left of the rasta once they are combined. Image below.
Capture1
The yellow lines now seem to be top right? Why are they not overlayed to look the same as above?Capture2
