How can I change the colorformat for KML? FME2015
  • September 11, 2018
  • 11 views
I'm making a tree map. Every tree species gets a different color with the FeatureColorSetter. I put the fme_color in the KMLstyler. But in google I only get one color. In the KML I do not get the hex colors.
I'm working in FME2015 due to the fact of an old smallworld application.
How can I change the colorsettings for KML?
Hi @vanranstamie,
Are you able to share your workspace or the parameter set up for these two transformers? As I would expect this translation to work.
mygis
Forum|alt.badge.img+14
  • September 13, 2018
I am guessing that your workspace is overwriting the colors somehow. Could you please share your workspace?
