How can I add elevation on arc without changing its structure?
  • Mar 17, 2019 7:14 PM UTC
  • 72 views
arthy
Forum|alt.badge.img+8
Hello,
I would like to add elevation values on arc without changing its structure.
Before, I have this arc
And after I would like the arc to have this where the highlighted values should be the elevation values
0684Q00000ArCU6QAN.pngSO far my idea to do that is to use
arc =feature.getGeometry()
feat.setStartPoint(fmeobjects.FMEPoint(feat.getStartPoint().getXYZ()[0], feat.getStartPoint().getXYZ()[1], elevation_start))
feat.EndStartPoint(fmeobjects.FMEPoint(feat.getEndtPoint().getXYZ()[0], feat.getEndPoint().getXYZ()[1], elevation_end]))
but it is not working.
Any hints?
  • Mar 18, 2019 5:20 AM UTC
If you need to convert an "Arc By Center Point" to an "Arc By Center Point With Ends", you can re-create required arc based on properties of the original arc using a constructor of fmboejcts.FMEArc with this signature. See the API documentation.
init(centerPoint, rotation, primaryRadius, secondaryRadius, startAngle, sweepAngle, startPoint, endPoint)
Creates an arc using the center point supplied, along with the supplied radii, angles, and points. All angles are CCW up from the horizontal, and are measured in degrees.
Parameters:
centerPoint (FMEPoint) – The centerPoint of the arc.
rotation (float) – The rotation of the arc.
primaryRadius (float) – The primary radius of the arc.
secondaryRadius (float) – The secondary radius of the arc.
startAngle (float) – The start angle of the arc.
sweepAngle (float) – The sweep angle of the arc.
startPoint (FMEPoint) – (Optional) The start point of the arc.
endPoint (FMEPoint) – (Optional) The end point of the arc.
Return type:
FMEArc
Returns:
An instance of an Arc Geometry object.
e.g.
import fmeobjects
def processFeature(feature):
    arc = feature.getGeometry()
    newArc = fmeobjects.FMEArc(
        arc.getCenterPoint(),
        arc.getRotation(),
        arc.getPrimaryRadius(),
        arc.getSecondaryRadius(),
        arc.getStartAngle(),
        arc.getSweepAngle(),
        arc.getStartPoint(),
        arc.getEndPoint()
    feature.setGeometry(newArc)
  • Mar 18, 2019 5:44 AM UTC
Parameters:
Return type:
FMEArc
Returns:
e.g.
import fmeobjects
        arc.getRotation(),
        arc.getEndPoint()
This script is also possible, if you just need to set z-coordinate to start and end points.
    elevation_start = 100
    elevation_end = 200
    p0 = arc.getStartPoint()
    p1 = arc.getEndPoint()
    p0.setZ(elevation_start)
    p1.setZ(elevation_end)
    arc.setStartPoint(p0)
    arc.setEndPoint(p1)
    feature.setGeometry(arc)
arthy
  • Mar 19, 2019 3:00 AM UTC
    elevation_end = 200
    arc.setEndPoint(p1)
Thanks @takashi
