Hi, I am running a workspace to transform my data into a .csv using pipe delimited characters to separate my data. The problem I am having is how to eliminate the pipe delimiters that are separating the rows. I showed an example below.
  • Jan 10, 2023 8:49 PM UTC
  • 62 views
FME_PipesseparatingrowsI want to remove all the extra pipe delimiters after the data. I would do it manually by I have over 10000 records. Please help.
caracadrian
Forum|alt.badge.img+23
  • Jan 11, 2023 6:05 AM UTC
You can use a Tester to test if the first attribute (col0) has a value and filter out the ALLPIPE lines.
Test for pipe
tomfriedl
Forum|alt.badge.img+14
  • Jan 11, 2023 7:29 AM UTC
I think is better to filter before you write data to CSV-file.
