Hi, I am having a problem where LAZ is not being read.
  • Mar 3, 2025 6:05 AM UTC
  • 9 replies
  • 265 views
sujitbhunia
Forum|alt.badge.img+3
Reading laz from Local / Network drive throws error: LAS reader: Failed to open file for reading. Please ensure that the file exists and you have sufficient privileges to read it.
Any ideas why this happens?
kailinatsafe
Forum|alt.badge.img+24
Hello ​@sujitbhunia, interesting. I have a few additional questions if you don’t mind!
  • What version and build of FME Form are you currently using? (Help > About FME Workbench)
  • Is there any other related messaging in the logfile that may be helpful? (eg. warnings, or errors).
  • Are you able to read or open the same file successfully in a different application? (eg. is this a purely FME issue or are other applications also unable to read the file?)
  • Are you able to share a sample LAZ file here for testing?
Happy to help, Kailin.
donalmateer
Forum|alt.badge.img+13
Hi ​@sujitbhunia,
Thnaks for posting!
Here’s some articles that may help with the issue:
Here are some troubleshooting steps that may help:
  • Test opening the file in another program.
  • Copy the file to your local machine and try again.
  • Check the FME log for addtional error messages.
Let me know if this helps!
sujitbhunia
  • Mar 5, 2025 5:58 AM UTC
Thanks ​@kailinatsafe for your answer
  • I am using FME version 2021 64 bit.
  • If I download the LAZ files from Azure storage to my local drive, I can read the files but it takes up more storage and takes longer to execute.
  • When trying to read Laz files from Azure storage using files path then it throws error "LAS reader: Failed to open file 'https://storageaccountName.blob.core.windows.net/pointcloud/LAZ/abc_laz_20190101.laz/abc_laz_20190101.laz' for reading.  Please ensure that the file exists and you have sufficient privileges to read it”.
sujitbhunia
  • Mar 5, 2025 8:43 AM UTC
Hi ​@sujitbhunia,
Thnaks for posting!
Hi ​@donalmateer  Thanks for your suggestion
  • If I copy the LAZ files from Azure storage to my local drive, then I can read the files but it takes up more storage and takes longer to execute.
  • But problems arise when reading laz data directly from Azure Storage.
donalmateer
Hi ​@sujitbhunia!
Thanks for the responses!
Here’s a suggestion that may resolve the issue.
It looks likt you’ll need to authenticate (read) through WaaFS.
Dataset drop down > Read File From Web > select appropriate azure storage.
sujitbhunia
  • Mar 6, 2025 8:31 AM UTC
Hi ​@sujitbhunia!
If I use "Dataset drop down > Read File From Web > select appropriate azure storage", there is an option to select only one file at a time but I have a folder that has more files to read.
If I select 1 file it works fine, but I am unable to select multiple folders.
donalmateer
Hi ​@sujitbhunia,
Thanks for comment! Have you tried using either the AzureBlobStorageConnector or AzureFileStorageConnector. This may help with the issue of only selecting one file!
Let me know if this helps! I’m going to recreated on my end and see if I can find a solution!
Thanks!
sujitbhunia
  • Mar 12, 2025 9:10 AM UTC
Hi ​@sujitbhunia,
Thanks!
Thanks ​@donalmateer ,
using AzureBlobStorageConnector we can only download/Upload files but there is no option to read files from Azure.
Thanks!
donalmateer
Hi ​@sujitbhunia, after further investigation unfrotunately it’s only possible to select one folder at a time. Using the LAS reader you can select multiple files when they’re on your local drive but unfortunately you can only select one folder at a time if ‘selecting a file from the web’.
