Help with Unzipper transformer
  • Dec 8, 2015 5:30 PM UTC
  • 64 views
Hello,
When I try to use the custom transformer "Unzipper" in 2015, it seems to work. A shape files in my zip file seem to be getting extracted into a temp directory on my C: drive, but once the workspace is finished running, the temp directoy disappear. Not sure how to make it work.
Thanks
erik_jan
Forum|alt.badge.img+26
  • Dec 8, 2015 5:34 PM UTC
You can point to a ZIP file using the Shape reader. You do not have to unpack the ZIP before reading the files anymore. Just use the ZIP file like you would use a directory.
  • Dec 8, 2015 6:53 PM UTC
Erik - Thanks. That works perfectly. A nice easy solution.
