Grouping in FME
  • January 21, 2025
  • 114 views
ohashkii
Forum|alt.badge.img+8
Hi
I am having an excel sheet like below. I need to group them in Field name route and assign a value for route field .
let's say (routeNo)  or any other unique value.
the grouping is based on finding a value that is considerable above of other previous records
below is 48. which is very big than other previous ones.
Any help is highly considered.
Route 1
Route 2
koulsoum
Forum|alt.badge.img+12
  • January 21, 2025
Hi ​@ohashkii ,
you can use a Sorter (grouping by Route) to sort your attribute ‘defy’ according to the Order ‘Descending’. And a Sampler ( same group by Route) to take the highest value, you can choose First N-feature.
Hoping this will helps you
geomancer
Forum|alt.badge.img+57
  • January 21, 2025
Use 'Enable Adjacent Feature Attributes’ in Attributemanager to look at the value of the previous feature.
See the attached workspace.
ohashkii
  • January 22, 2025
Thank you very much...works well.
