Get 3Dsolids instead of Polyface mesh by export to dwg
  • Jul 11, 2019 2:12 PM UTC
  • 229 views
sprongandre
When I export a 3D solid to dwg I get a Polyface mesh instead of a 3Dsolid.
How do I get 3Dsolids?
itsmatt
Forum|alt.badge.img+48
  • Jul 22, 2019 1:47 PM UTC
Have you tried the RealDWG writer? This might give you better results than the ACAD writer
umapper1
Forum|alt.badge.img+5
  • Jul 23, 2019 2:10 PM UTC
I'm interested in this too. I thought this might be an FME limitation on how it generates 3D solids. It looks like it triangulates as a surface rather than what we would expect from an Autocad 3D Solid shape. I'm just speculating as a rookie here so I'd be keen to hear from a more advanced FME user..?
sprongandre
Solved!>It was a combination between the geometrycoercer(set to fme_berp_solid) and the RealDWG writer. :-)
gvenhorst
  • Apr 6, 2022 6:03 AM UTC
When I open the dwg drawing the object is converted to a Mesh and not to a Solid.
Do you have an example Workspace for me?
