Formatting the resulting interval (ISO Duration)
itay
Forum|alt.badge.img+17
I am currently calculating date time intervals via the DateTimeCalculator that result is ISO Duration format (PT28M20S for example)
I would like to format the result into a FME datetime but havent found a way to do it with the DateTimeConverter. I can split the value into its parts and then combine them but there should be an easier way...
I am surprised that FME doesn't recognize and can parse this date time notation, after all FME is producing it....
Using FME 2019.2.0.0 build 19801
Could be I am missing something, any assistance would be appreciated.
Cheers,
Itay
Forum|alt.badge.img+32
  • April 23, 2020
PT28M20S is a duration of 28 minutes and 20 seconds, it can't be converted to an FME datetime. Or do you mean you want to add it onto a known date time?
itay
  • April 23, 2020
Hi @ebygomm,
No I want to format it into a FME datetime, so that I can eventually write it out as a datetime.
So I guess it's gonna be 'the hard way'....padding, etc
  • April 23, 2020
itay wrote:
Hi @ebygomm,
But it's not a date time it's a duration - what datetime would you expect PT28M20S to become?
itay
  • April 23, 2020
True, I need to write it into an oracle date time data type.
@itay Oracle and other databases do have Interval date types. This isn't something we have tackled in FME yet so you'll have to parse the FME Duration for now. Also, I don't think the FME feature types support the 'interval' data types so you'll have to create the table before you write to it.
itay
  • April 23, 2020
Thx for the info @markatsafe, luckily the table already exists.
  • April 23, 2020
If you're actually wanting to write to an interval date type column if you want to avoid parsing the date time interval you can create a dummy date which contains the interval added onto an arbitrary date
and write that into a temporary table. Then populate the interval column with a query by taking the arbitrary date away from the dummy date.
FME doesn't play nicely with columns of interval date types (unless this has changed in 2020) so that's something to be aware of. You cannot 'see' the interval columns with the reader, you can read with sqlcreator/sqlexecutor if you convert them (and know they're there and their names)
warrendev
Forum|alt.badge.img+23
  • April 23, 2020
itay wrote:
Hi @ebygomm,
You could probably do some string manipulation, but there is also an easy to use python library isodate that will do it for you.
pip install isodate
import isodate
duration = 'PT28M20S'
print(isodate.parse_duration(duration))
Result
0:28:20
itay
  • April 23, 2020
pip install isodate
import isodate
Result
0:28:20
Hi @warrengis, that does look interesting...
thx for the tip.
itay
  • April 23, 2020
that is a very interesting approach, thx for the tip.
