FME workbench and transactionality when FAILED
  • August 30, 2018
  • 18 views
giosp
I'm testing a workflow that permit to rollback all the changes made in a workbench execution. There is a possibility to rollback some operations from start to end including the truncate operation?
I have a workflow that read data from a source and write in another one. Writers are set to truncate. If the write process has an error and the workbanch has a failure the truncate process is commited. I'm not able to rollback before the truncate step. Anyone has an idea?
A possibility is to have a staging area and if the workbench is completed without problems a second workflow start with the real update from staging area to the work area.
  • August 30, 2018
I agree fully about using a staging area, I would consider that the best-practice solution.
When data has been fully loaded into the staging area it's usually very simple to copy the data into the production schema using a SQLExecutor and something like
begin
  delete from prod.my_table;
  insert into prod.my_table select * from staging.my_table;
  commit;
end;
Not only would that be a single transaction, but it would also be much faster than doing the transfer with FME since no data leaves the database, which means reduced down-time on the production datasets.
