FME TRANSFORMER
  • April 18, 2013
  • 44 views
HI ALL,
ANYBODY KNOW HOW TO SET UP LAYER COLOR IN FME?I HAVE CAD DRAWING THAT CONSIST OF CERTAIN LAYERS. I WANT TO USE FME TO SET SAME COLOR SO THAT I CAN EASY DISTINGUISH EVERY LAYER IN ARCGIS. ANY FME SPECIALIST,PLEASE HELP ME..WHAT KIND OF TRANSFORMER THAT I SHOULD USE?
THANKS..
mark2atsafe
Forum|alt.badge.img+59
  • April 18, 2013
I don't think you can, unless you are writing to SDE. Neither Geodatabase nor Shape store color information.
You could always write the value of the format attribute fme_color to a user attribute in the output. That way you would have a record of it in your data and could maybe use that to color features in ArcGIS?
Regards
Mark
  • April 18, 2013
Means that the color information only stored in attribute table in GIS?not apply at feature layer?..ok i'm understand..Actually i have work at standardization department, so if i want to standardize color in term of CAD and GIS layer, i must set it for two times in GIS and CAD?
kathyross
Participant
Forum|alt.badge.img+9
  • Participant
  • April 21, 2013
Yes.
If you wish to standardise the colours between CAD and ArcGIS (Shape and GeoDatabase) layers, you will unfortunately need to set the colours twice.
