FME_SQL_DELIMITER won't work:
  • September 25, 2018
  • 7 replies
  • 56 views
The next query results in an error (ORA-00900: Invalid SQL-statement.)
FME_SQL_DELIMITER /
begin
update tbx.ext_compare_person
set   gesnam_d           = tbx.diakriet_cip(gesnam_d,sourcekey,'GNAAM')
,     gesvor             = tbx.diakriet_cip(gesvor,sourcekey,'VNAAM')
,     gesnam_d_p         = tbx.diakriet_cip(gesnam_d_partner,sourcekey,'GNAAM_P')
where organisatiecode = 'ABDC'
and   applicatiecode = 'ABC';
end;
commit;
What am I doing wrong?Thanks in advance.
oscard
Forum|alt.badge.img+22
FME_SQL_DELIMITER is used to indicate the character that is going to separate one SQL sentence from another.
Usually is ";".
I'm not sure what you are doing with the '/' character.
More info here: https://knowledge.safe.com/articles/516/splitting-sql-statements-using-the-fme-sql-delimit.html
Hi Oscard,
Thank you for your answer.
I need the SQL Executor to update several columns in Oracle based on a function (diakriet_cip). First I tried this:
FME_SQL_DELIMITER ;
commit;
This results in the same error 'ORA-00900: Invalid SQL-statement'.
oscard
reijnen wrote:
Hi Oscard,
FME_SQL_DELIMITER ;
commit;
And this?
FME_SQL_DELIMITER /
set   gesnam_d           = tbx.diakriet_cip(gesnam_d,sourcekey,'GNAAM'),
gesvor             = tbx.diakriet_cip(gesvor,sourcekey,'VNAAM'),
commit;
Source: https://knowledge.safe.com/questions/66481/sqlexecutor-atomic-transaction-by-commit.html
nielsgerrits
Forum|alt.badge.img+58
reijnen wrote:
Hi Oscard,
FME_SQL_DELIMITER ;
commit;
You won't need the "commit;" part using the SQLExecutor as it is autocommitting.
Hi Niels, thank you. This worked! Is there a way to show (e.g. in the log) how many rows were updated?
oscard
I suspected that much. I am checking the docs, but I can't find any mention about the autocommit. It would be nice if there were a mention about it.
nielsgerrits
Good question, I can't get it to work either. Maybe @SteveAtSafe can shine a light on this? The code works but as no records are returned no feature leaves the Result port so i is lost... :-)
FME_SQL_DELIMITER /
DECLARE
  i number := 0;
BEGIN
    update TABLE1
    set COLUMN1 = 'testvalue';
    i := sql%rowcount;
END;
A workaround is to create a table RESULT with a column RESULT and add one empty record. Then update the value i to table RESULT column RESULT and then add another SQLExecutor to read table RESULT column RESULT.
FME_SQL_DELIMITER /
DECLARE
  i number := 0;
BEGIN
    update TABLE1
    i := sql%rowcount;
    update RESULT set RESULT = (i);
END;
It works but it feels not right.
