FME Server email read from fme user
  • February 26, 2019
  • 76 views
giosp
I use FME Server 2018. I'd like to send the result of a job to the user that submitted the job. I'd like to retrieve the email from the users list inside fme server because there are synchronized with Active Directory. With the FME_SECURITY_USER I've got the user but there aren't others FME_SERVER variables that contains the email. How I can get this information?
Thank you for suggestions.
Best answer by david_r
I suspect the only option is to use the REST API to retrieve the user properties based on FME_SECURITY_USER:
GET /security/accounts/$(FME_SECURITY_USER)
Response:
account {
  email (string, optional): Email of the account,
  enabled (boolean): Whether the account is currently enabled or not,
  fullName (string): Full name of the account,
  name (string): Unique name of the account,
  password (string): Account password,
  roles (array[string], optional): Roles assigned to the account,
  type (string) = ['System' or 'Ldap']: Type of the account
You can use the FME_SERVER_HOST + FME_SERVER_PORT as a basis for the query URL.
  • February 26, 2019
Response:
account {
giosp
  • February 27, 2019
Response:
account {
Hi @david_r , thank you for your suggestion. Is a good idea. Yesterday I've cheked the other way to querying the useraccount table in fmeserver db and get the mail from it and works. I will to switch to api to have more flexibility in the future.
I open an Idea to create a new variables like FME_SECURITY_USER but f.e. FME_SECURITY_USER_EMAIL with the email automagically set by fme.
Thank you
  • February 27, 2019
Thank you
That's a nice workaround, but since you're using an undocumented function be sure to specifically re-test this every time you upgrade FME Server.
I voted for your idea, it's a good one.
