Fme not reading all the features coming out of sql executor. surprised!!!
f.kemminje
Forum|alt.badge.img+11
When I execute the query in TOAD there are 1.6 million records are fetching. But when i used the same query inside fme it fetched only 138000(138 thousand records), And i Am using http caller in this fmw file. Is the http caller culprit here?
fmw screen shot attached.
toad shows 1.47 millon because already 138 k records written to destination and we changed the
flag field nax match status to yes. and in this query we take only nax match status is NULL
explanation :
I used this statement inside fme using executor
next i am creating text string to ingest to HTTP Caller
Httpcaller takes approx 1 second to get the response
everything worked good, fme said successful, No error msg. But only 138 thousand came to destination table. i am really surprised.
how can we fix this issue?
  • May 8, 2018
I would start by further analyzing your data and your workspace, e.g.
  • Are you using the exact same SQL select statement in FME as in TOAD?
  • Are you connecting to the same database instance in FME and in TOAD?
  • If your SQL is dynamic based on incoming attributes, are the attributes always present and do they contain the expected values?
  • Try generating the complete SQL statements in e.g. an AttributeCreator and send the statement to the log and copy/paste to TOAD: does the result there match the result in FME?
Using breakpoints in FME is very helpful when problems like these occur.
For what it's worth, I've never had any problems with the SQLExecutor not returning all the records, even for multi-million record counts.
Forum|alt.badge.img+50
Just a general note: the HTTPCaller will send a call out for every feature that's being passed through it, as soon as the feature passes through it. I've done that with much less features on a server in a local network and effectively did a denial-of-service attack on it. I'm not saying that this is the case here, but it may be. In that case a Decelerator can be used to slow things down (max features per second or a per-feature delay, but with 1.6M features you probably don't want that)
  • May 8, 2018
Totally agree. Actually, I once had to do something like that to geocode about a million addresses and it took about 12 days of non-stop processing. I also had to contact the server admin to avoid getting black-listed for this exact reason.
f.kemminje
  • May 10, 2018
@david_r
David My answers below..
  • yes
  • yes both are same
  • count of records in the table not changing
  • yes matches
Moreover when i remove http caller from my fmw. I am able to receive all the records from sql executor.
When I checked this issue with my colleague , even he had this issue before.
f.kemminje
  • May 10, 2018
Now i used feature holder transformer after sqlexecutor and i got all the 1.6 million records from the sql executor. and it is running now. i need to check whether all the output features from feature holder are going thru http caller or not
it is in the process...
i will tell you the result. will see
  • May 10, 2018
f.kemminje wrote:
@david_r
  • yes
  • yes both are same
  • yes matches
I'd add another question.
  • Did the entire translation complete successfully?
  • May 11, 2018
f.kemminje wrote:
@david_r
  • yes
  • yes both are same
  • yes matches
Did you check for warnings or other "suspicious" messages in the FME log?
dnaumov
Forum|alt.badge.img+8
  • August 27, 2019
Same issues here. I am reading features from Oracle table using SQL Creator but it is not reading all of the features for whatever reasons. Log file doesn't reports any errors. Has it something to do with the WorkspaceRunner which does some processing and updates the same rows at the end?
Was the root cause found?
sigtill
Forum|alt.badge.img+24
  • August 27, 2019
Hi @danaumov - Do you only have a SQLCreator in the workspace? Can you try with an empty workspace and use only an SQLCreator to see if this can read all the features. Also can you paste the complete SQL used here?
sigtill
  • August 27, 2019
I would recommend to add a Attributecreator before the SQLExecutor and a Logger also. This way you can see the actual query being used in the logfile on FME Server also:
dnaumov
  • August 27, 2019
In the Oracle trace I found this error. ORA-01555: snapshot too old. This is the root cause but strangely FME doesn't pick this up and doesn't report the error in the FME log, quite the opposite it says everything was a success.
sigtill
  • August 27, 2019
@danaumov - did you see this on the "Oracle side" of things? Havent used Oracle a lot so sorry for the stupid questions :).
dnaumov
  • August 27, 2019
Yes, in the Oracle logs but it doesn't show up in the FME log. Oracle errors usually do show up in FME logs but for whatever reason this one wasn't caught by FME.
  • August 27, 2019
Before we blame FME, don't forget that there's also the added layer of the Oracle client. I'm curious to know if you can execute the same query using e.g. SQLDeveloper on the same client and not get any errors?
dnaumov
  • August 27, 2019
Yes you will get the same error in SQL Developer. It is an Oracle error which has nothing to do with FME but the issue is that FME is not capturing it.
  • August 27, 2019
That sounds very weird (and a tad unlikely, I must admit). Regardless, it sounds like a case for Safe support.
