FME Hub URL
  • Jan 13, 2026 5:05 PM UTC
  • 5 replies
  • 115 views
Forum|alt.badge.img+54
In the answer to this question
Esri ArcGIS Feature Service - Reads Dates as Epoch Milliseconds | Community
a URL is given to the FME hub which doesn’t match the address I’m used to seeing for FME Hub, crucially the info on this package is all quite different too
This is what i’m familiar with
hub.safe.com/publishers/safe/packages/esri-agol
Esri ArcGIS Connector - FME Hub
and this is the link provided
hub.fme.co/publishers/safe/packages/esri-agol
Best answer by daveatsafe
It appears that we provided a link to our staging environment by mistake. Please continue to use the link to FME Hub that you are all accustomed to.
hkingsbury
Forum|alt.badge.img+73
  • Jan 13, 2026 7:03 PM UTC
Oh, i just noticed the differences as well!!
Maybe my comments below are not correct….
Could still be a mistype, maybe fme.co is a test instance?
I suspect thats just a typo and is meant to be ‘.com’
Looking at the WHOIS for fme.co you can see that it is owned by Safe - https://who.is/whois/fme.co
I suspect they’ve set this up to capture users who mistype the URL. I do note that fme.co goes nowhere however!
  • Jan 13, 2026 7:07 PM UTC
The full link does go somewhere though, to a page that says the latest Esri connector package released is 3.20.0
The usual FME hub says the latest Esri connector package released is 3.16
hkingsbury
  • Jan 13, 2026 7:11 PM UTC
​@danielleatsafe are you able to shed any light on this?
salvaleonrp
Forum|alt.badge.img+23
  • Jan 13, 2026 9:38 PM UTC
That looks weird…
​@siennaatsafe
daveatsafe
Forum|alt.badge.img+24
  • Jan 14, 2026 3:38 PM UTC
