Esri ArcGIS Feature Service - Reads Dates as Epoch Milliseconds
  • Aug 30, 2025 8:28 AM UTC
  • 21 replies
  • 1054 views
braggken
Forum|alt.badge.img+9
Hi Folks,
For reading and writing ArcGIS Online feature services we are transitioning to the newer Esri ArcGIS Feature Service format in FME Flow 2024.2 from the soon to be deprecated Esri ArcGIS Online (AGOL) Feature Service (at least according to this article)
My problem is that now the reader seems to read dates as Epoch time in milliseconds! Obviously this can be worked around but it is quite painful to fix up the many workspaces we have which used the older reader and read dates as YYYYMMDD etc. especially when writing back to AGOL where the dates have to be back in  YYYYMMDD.
Any thoughts?
Best answer by TandraAtSafe
The Esri ArcGIS Connector has been updated on FME Hub to version 3.13.2 and resolves the issue above.
Forum|alt.badge.img+54
  • Sep 2, 2025 10:39 AM UTC
Yuck!
Can confirm the same with an Enterprise Source Type with the Esri ArcGIS Feature Service Reader
​@braggken - have you confirmed that you can’t write the epoch time using the newer writer and conversion is required?
I’ve not managed to get the newer writer working at all yet...
braggken
  • Sep 2, 2025 11:47 AM UTC
Thanks for confirming ​@ebygomm - can you tell me your version of FME please?
No I can’t write epoch time with the new writer, at least not an existing AGOL feature layer.  The other hitch I noticed is that where there was already a GlobalID field in the layer it seems we now have to send a guid along whereas before that was not needed.
We are going to have to migrate our Enteprise readers/writers also which will be a much bigger job.
  • Sep 2, 2025 12:30 PM UTC
Using the same package (Esri ArcGIS Connector 3.11.1) I've tested connecting from
  • FME 2024.1.0.0 Build 24612
  • FME 2025.1.0.1 Build 25609
  • Sep 2, 2025 4:32 PM UTC
Further to the above, I’ve now managed to update an Enterprise feature service using the Esri ArcGIS Feature Service writer - I get a permissions issue if i try to use token authentication but it worked with Oauth authentication.
I can update a date field sending either milliseconds since epoch or an FME date time (attribute type needs to be datetime) to the writer
geospatialize
Esri data types for Feature Services are always such a pain… Especially the datetime datatypes.
To convert UNIX millisecond epoch time to YYYYMMDD format, you need to use the AttributeManager’s Arithmetic Editor to first convert the UNIX milliseconds to seconds (e.g., @Value(ATTRIBUTENAME)/1000). Then, use the DateTimeConverter transformer to format UNIX seconds into YYYYMMDD. Depending on your workflow, you could create a dynamic workspace that only rectifies the date values for Feature Services.
Additionally, there’s also a quirk with Esri Feature Services where you cannot write the value 19700101000000 and Esri converting Date Time value to local time zones (Note: I am not sure if this behavior is still present with Esri Feature Services). My memory is a bit hazy, but you can find the thread here:
braggken
  • Sep 3, 2025 6:25 AM UTC
Yes thanks ​@geospatialize  as I mentioned in the inital post,  “Obviously this can be worked around ..“  but its good to have posted the details.
But the issue is the way datetimes are read by the new reader has changed. We have over 100 workspaces that read and write AGOL and Portal many of which manipulate datetimes within.  Also rather annoyingly, the new datetime format cannot be handled by DateTimeConverter so as you pointed out, the work-around involves an additional step for every datetime attribute being handled to convert from milliseconds to seconds.
  • Sep 3, 2025 7:42 AM UTC
It certainly gives no indication in the article “Working with Esri ArcGIS Feature Services in FME” that there is a fundamental change in the data being returned when using the new reader v the old. And it concerns me that there might be other similar discrepancies.
oscard
Forum|alt.badge.img+23
  • Sep 9, 2025 12:11 PM UTC
About the date using the new Writer, I have also been able to insert dates in FME format, but it keeps throwing errors when I use dates in milliseconds (even though the value is exactly the same as the ArcGIS feature Reader returns).
I have made sure to set the type as “datetime” with An AttributeManager. Did you do anything else to make it work with milliseconds?
davechoi
Forum|alt.badge.img+15
  • Sep 9, 2025 4:06 PM UTC
Hi folks,
I've submitted a ticket for this behavior (FMEENGINE-87880).
The current workaround for the ArcGIS Feature Service Writer to accept UNIX milliseconds (if Data type is String) is to set the Attribute Definition as Manual and specify the Attribute with the Date value in an arithmetic editor within the Writer's User Attributes.
I apologize for this inconvenience. Thank you for your understanding.
  • Sep 9, 2025 4:24 PM UTC
So i hadn’t tried to insert a new feature with a date in milliseconds, just update an existing and that worked with no other changes other than setting a new value in the AttributeCreator (I thought it wasn’t updated for a while until i realised that although milliseconds are returned, only whole seconds seem to be accepted, i.e. a value of 1757434408001 ends up as 1757434408000)
  • Sep 9, 2025 4:33 PM UTC
I don’t even want to look into how this impacts dynamic workflows….
madeleine_rfs
Hi folks,
What about the ArcGIS Feature Service Reader?
I’ve tried all of the above workarounds for a dynamic ArcGIS Feature Service reader, which shows date fields as ‘Date’ in the Attributes list within the Navigator tree, and int64 in the AttributeManager.
I really don’t want to use a non-dynamic reader because I’m reading hundreds of attributes (don’t ask...), and it will be a massive pain to manage them manually.
I can’t, for the life of me, get DateTimeConverter to recognise any of the time attributes from the ArcGIS Feature Service reader (connected to an ArcGIS Online instance), irrespective of whether I convert them, change the data type, or divide by 1000 to bring them seconds units.
Example time: 1760436656063
The only other potential workaround I can think of, is to write a Python Caller that does the conversion but that’s going to be a pain, and waste work, to implement.
Any ideas?
salvaleonrp
  • Oct 14, 2025 3:00 PM UTC
​@braggken the article was updated ten days ago and gives the detail to this question.
Hope this will help folks who find this issue.
The way its read from the ArcGIS Data Store has not changed. Safe and ESRI both made it easy for end user by converting them whether its in the Workbench app in the legacy formats or the Esri web online maps and feature service tables.
Why Safe decided to leave the conversion for workspace authors like us in the new ESRI ArcGIS Feature Servcice format must have been given due consideration. I would assume keeping this in your workflow as epoch time would address end users demand to allow macine readable analyses that will later be converted to human readable downstream.
There will be pains with migrating older formats expecially for dynamic workflows and that would probably be another good article to ask for ​@ebygomm.
nathanherzog
For anyone that has had continued problems attempting to use the DateTimeConverter, I found a silly solution in another thread that resolved it for me.
After converting Epoch milliseconds to Epoch seconds using the Arithmetic Editor in Attribute Manager as noted above (@Value(ATTRIBUTENAME)/1000)
When feeding the result into the DateTimeConverter, do not use the down-arrow to select the attribute to convert. This will cause it to use the literal string instead of the actual value, and result in an error.
Instead, use the three dots (...) and select the attribute in the list. It should run without error now.
​​​​​Do not do this! ^
Select from the list instead
TandraAtSafe
Forum|alt.badge.img+8
  • Nov 7, 2025 9:57 PM UTC
sammy
Forum|alt.badge.img+27
  • Nov 13, 2025 5:20 PM UTC
​@TandraAtSafe I am using the Esri ArcGIS Feature Service Reader in package version 3.13.2 but still seeing the same issue with the dates in FME Form 2024.2.2.0 (20250114 - Build 24820 - WIN64).
If I try to run it through DateTimeConverter I get the following rejection message:
“CREATIONDATE: The epoch time is out of range. Please ensure it is specified in seconds, and not in milliseconds or microseconds.”
FME Hub says the package was last updated Oct 31.
Is there a newer version of the package that resolves this issue?
Similarly to braggken my workbenches were built on YYYYMMDDHHMMSS format and retrofitting each one will be a pain.
fbruimte
  • Nov 24, 2025 3:50 PM UTC
Unfortunately we still experience the same problems with version 3.13.2 just as mentioned by sammy.
The history of the package shows the following fix at 3.13.2:
  • Writer: Ensure epoch millisecond date format is accepted. (FMEENGINE-87880)
This suggests something is fixed for the writer, but the problem described in this topic involves the reader. And the different behaviour to the old reader when reading date fields.
davechoi
  • Nov 25, 2025 11:00 PM UTC
Hi everyone,
Esri ArcGIS Connector 3.13.2+ resolves the issue of writing UNIX Epoch Milliseconds to Feature Service, so an arithmetic editor is no longer required.
Our developers are working on an option for the Esri ArcGIS Feature Service format reader to read dates in FME datetime in addition to reading datetime values as-is from the data store (FMEENGINE-88767).
Apologies for any confusion, and we appreciate everyone's patience throughout this process.
panda
Forum|alt.badge.img+20
  • Dec 10, 2025 5:23 PM UTC
​@davechoi Thank you for the updates. Can you verify that if when the fix has been implemented for FMEENGINE-88767, what format would it be? Epoch time? or matching the original old AGOL reader?
I’m currently in the process of upgrading our old FME workspace to use the new ESRI ArcGIS Feature Service format reader. I just want to make sure that format will match the updates so it will be ready when the update has been pushed.
davechoi
  • Dec 10, 2025 6:56 PM UTC
​@panda The fix has been released few days ago! You will have the option to choose between Epoch time and FME datetime (old AGOL/Portal readers).
Please upgrade to the latest version of the FME Package for this change. Also be sure to check out the change log by selecting the History Section on this page: https://hub.safe.com/publishers/safe/packages/esri-agol
sammy
  • Dec 10, 2025 9:16 PM UTC
​@davechoi Thank you for the update. I did a quick test using the “FME Default” option and the date fields matched my original workbenches. YAY! 🙂 I very much appreciate having this option!
