Filter by date value - Select date value starting with "2023", "2022", etc.
  • Feb 23, 2023 3:12 PM UTC
  • 5 replies
  • 88 views
In SQL, it's possible to select all your data starting with "2023" like this :
SELECT *
FROM mydata
WHERE date LIKE "2023%"
Is there a way to do it with FME?
I have already apply a "DateTimeConverter" to convert my data in FME format (20230223).
I see on FME Workbanch that there is a "SQLCreator", but I need to import my data from a url and not from an DataBase like PostGIS
Best answer by david_r
The easiest is probably to use a Tester with a criteria to check for "starts with".
  • Feb 23, 2023 3:15 PM UTC
danilo_fme
Forum|alt.badge.img+58
  • Feb 23, 2023 3:18 PM UTC
Hi @geo.uqam​
You can use the Transformer Tester.
In the configuration of Tester, has a option Begin With.
Thanks in Advance,
It works! Thank you, it is appreciated.
danilo_fme
  • Feb 23, 2023 3:19 PM UTC
Same time :)
  • Feb 23, 2023 3:22 PM UTC
Same time :)
That was my very first question. Now I know that there is a very active community ready to help. Thank you!😀
