Feature merger join on problems?
  • Nov 20, 2017 9:32 AM UTC
  • 68 views
Hi! My problem is that I have 2 readers combined, en excel sheet and a path folder with subfolders and documents inside. The inspector reads them without problem. At a certain point they go to a feature merger, from where I get an error report. The error reports shows that non of the documents from the folders are present. Does anybody know why that happens? The next screenshot shows how are they connected and what happens. Those 21 unmerged requestor documents should not go to the error report because they are present.
Any help?? Thanks in advance. I am not very good at this but I try...
Best answer by takashi
Hi @ninani, firstly make sure that every "folder_filename" of Requestor contains exactly same string as one of "path_windo..." value from Supplier.
  • Nov 20, 2017 11:28 AM UTC
  • Nov 27, 2017 11:55 AM UTC
Thanks for your answer!
