Fail to convert lines to polygons correctly,
  • Sep 7, 2014 3:58 PM UTC
  • 17 replies
  • 115 views
jamal
Forum|alt.badge.img+5
Fail to convert lines to polygon correctly,
I have applied the workbench below to first clean the lines and then to convert them to polygons. The correct number of polygons should match the number of texts. My thought is that the tools applied to clean the lines are not sufficient.
CAD file:
http://www.mediafire.com/download/742ckkkp6jaxnm7/Parcels_Al_Samou_03.dwg
What other tools should be included in the workbench to first clean the lines:
1. Remove duplicates
2. Ensure lines snapping
Thank you
Best
Jamal
  • Sep 8, 2014 12:59 AM UTC
Hi Jamal,
I think segment snapping before the Intersector would be effective. And stroking arcs (and ellipses if exist) before the snapping might also be effective.
In addition, found these exceptional cases in the data.
1) three polygons that contain multiple texts for each.
2) one polygon that contains no text.
3) one text that does not correspond to any polygon.
4) a few lines that don't become polygon edges.
Takashi
  • Sep 8, 2014 1:06 AM UTC
5) two texts that duplicate about both geometry and text string.
fmelizard
Forum|alt.badge.img+22
  • Sep 8, 2014 7:40 AM UTC
I agree with Takashi, serious data integrity checks and cleaning should be done before transformation to polygons.
jamal
  • Sep 8, 2014 3:59 PM UTC
Thanks Takashi and ETLS-Itay,
Sure the CAD data is really “dirty”. This is why we need to clean it as much as possible.
1. I have applied the ArcStroker
2. But couldn’t find the “segment snapping” tool.
However, I think that the number of polygons derived from lines should be CLOSE to the number of texts. Otherwise, this will indicate that the lines are not yet cleaned.
By the way, there is no effect neither for the “ArcStroker” nor for the “matcher”.
What other tools should be applied to make the number of polygons quite close to the number of texts?
  • Sep 8, 2014 4:08 PM UTC
Take a look at the "Snapping Type" parameter of the Snapper transformer.
jamal
  • Sep 8, 2014 5:28 PM UTC
You are correct Takashi,
The data is dirty to a degree that all tools will never clean it. I check the resulted polygons and found out many slivers.
Better if the data is correct at the level of AutoCAD and then applying FME.
  • Sep 8, 2014 11:34 PM UTC
Why not try Snapper (Snapping Type: Segment Snapping) ?
I inspected your data with this workspace, FYI.
jamal
  • Sep 9, 2014 4:07 PM UTC
Many thanks Takashi. It is much better now with the snapper. But we still need some manual work on the original CAD data.
Best
Jamal
  • Sep 10, 2014 10:18 AM UTC
Please check again my first post in this thread.
"I think segment snapping before the Intersector would be effective. And stroking arcs (and ellipses if exist) before the snapping might also be effective."
This is the result of my inspection about your data. Red polygon contains no text; Green polygons contain multiple texts for each; Red text (left-top corner) does not correspond to any polygon.
jamal
  • Sep 10, 2014 4:52 PM UTC
Very much appreciated Takashi for the massive efforts. Your valuable advices introduce better results
I tried to build same workbench as yours but
1. I fail to build the testfilter
2. To enlarge the text to be visible in the “fme inspector”
Could you please share your workbench?
  • Sep 11, 2014 1:09 AM UTC
Find this link.
https://www.dropbox.com/s/drgpym10j6ty7sp/140911_acad2none.fmw?dl=0
To enlarge text size in FME Data Inspector, modify "fme_text_size" attribute value.
jamal
  • Sep 11, 2014 8:22 AM UTC
Thank you very much Takashi,
I have applied the same settings for the “testfilter” but with no luck.
CAD file:
http://www.mediafire.com/download/or2juzglb27ja7g/Parcels_Al_Samou_04.dwg
Workbench:
http://www.mediafire.com/view/6prk49av2uk621k/Parcels_CAD_To_GIS_05.fmw
jamal
  • Sep 11, 2014 8:23 AM UTC
I didn't get the same result for:
Single text
Multiple text
No text
  • Sep 11, 2014 9:20 AM UTC
The SpatialRelator outputs the Requestor features after collecting attributes of related Supplier(s).
And, which of the ArcStroker and the Snapper should be used previously?
See more carefully my workspace, posts, and related help docs., please.
jamal
  • Sep 11, 2014 10:35 AM UTC
Perfect. This is really great.
Very much appreciated for the massive efforts and help.
ponceta
Forum|alt.badge.img+7
  • Jun 22, 2017 12:28 PM UTC
The LineCloser transformer has done the job in my case.
ponceta
  • Jun 22, 2017 12:30 PM UTC
I didn't had the snapping needs btw.
