Extracting x, y, z values of lines and polylines within a AutoCAD .dwg file
  • February 12, 2020
  • 579 views
I have a few AutoCAD drawing files (.dwg) that have a number of 2D and 3D lines and polylines. My goal is to extract all the vertices of each individual line so that I can store it within my GIS database (PostgreSQL). Additionally, I want to extract the layer name and a few other attributes.
Is there a way to extract this data and convert it into a Shape file (.shp) ?
Cheers
erik_jan
Forum|alt.badge.img+20
  • February 12, 2020
For Extracting X, Y and Z you could use the CoordinateExtractor transformer.
The name of the AutoCAD layer is stored in the fme_feature_type attribute, that can be exposed on the reader feature types.
Hope this helps.
katitahonen
What is the polygon z-points does not show with this, what to do? I know they are in there because it´s measured data, but how to get it out? This did not work.
  • K
