Hello,
I have two polygon datasets: folios and townlands(see image below). For the most part, the folios(grey outline) are nested neatly within the townlands dataset(red outline) so the outer folio boundaries are shared with the townlands’ boundaries. I would like to extract the areas where these two datasets’ polygon boundaries cross...i.e. where they are not nested neatly. Most of these will be slivers. SpatialRelator(and Tester) helps to extract the offending folios using the Spatial Predicates Test: "Requestor OGC-Overlaps Supplier" however the output is the entire folio polygons(not overlapping area) as SpatialRelator does not edit the input dataset. I am unsure as to what to do next, I would like to automate this process in FME Server if possible so having one workflow would be useful.
