extra_clipper_feature errror?
  • Mar 26, 2018 1:50 AM UTC
  • 80 views
Hi, I can't find an explanation in the doc about what this error means so that I can avoid it. I'm using a Clipper with Clipper Type 'clippers first' for performance. I'm grouping by row and column tiler output columns which are unique although I do have multipart polygons.
  • Mar 26, 2018 2:08 AM UTC
Hi @tfsrichard, you can use the "Clippers First" option only if it's sure that all the Clipper features will have been entered into the Clipper transformer before the first Clipee feature. Is it sure?
  • Mar 26, 2018 2:13 AM UTC
Thanks @takashi I do have my clipper above my clippee in the navigator order but clippee's seem to be read in first.
  • Mar 26, 2018 2:35 AM UTC
The reader for Clippers should work first if you have it above the reader for Clipees in the Navigator.
However, if you have inserted a blocking-transformer between the reader feauture type and the Clipper port, all the features will be stored there to be processed, so the order of readers won't be preserved.
Perhaps have you inserted a Tiler before the Clipper port? The Tiler is a blocking-transformer. If you have inserted it, you cannot use the "Clippers First" option, unless you implement a process to control the order of the features explicitly.
  • Mar 26, 2018 3:08 AM UTC
Thanks Takashi, yes I have blocking transformer (tiler) before the clipper.
