Extend Line to center of circle
  • May 22, 2019 6:14 AM UTC
  • 28 replies
  • 272 views
Show first post
Hi All,
I have this exact same issue, including the two-ends extension part, but none of the example workbenches that were in this answer are attached any more - is there any way the examples can be re-attached? I'd really love to not have to re-invent the wheel! @deanhowell​  @pratap​ @Mark Stoakes​ ??
Thank you in advance!
Katrina
@katrinaopperman​  You should be able to use a combination of ArcPropertyExtractor (or EllipsePropertyextractor) and AnchorSnapper should do it:
workspace
Hello @katrinaopperman​ I will dig up the solution we used and post it here for you.​
Thank you @deanhowell​ and @pratap! That's quite a workbench! As you say, best community ever!
workspace
Thanks @Mark Stoakes​ - I'll have a go.
