extend a raster
  • Mar 12, 2020 4:52 PM UTC
  • 213 views
oliver.morris
Forum|alt.badge.img+14
Whats the best way to extend a raster to fit a larger extent, filling the additional space with the nodata value of the raster?
Many Thanks for the help
daveatsafe
Forum|alt.badge.img+24
  • Mar 12, 2020 9:08 PM UTC
Hi @olivermorris,
The RasterSubsetter transformer can also pad a raster with empty (or transparent for RGBA rasters) pixels, if the start column and row are set to 0 and the number of rows and columns are set to the entire raster. The number of rows and columns in any raster can extracted using a RasterPropertyExtractor transformer.
oliver.morris
  • Mar 17, 2020 2:11 PM UTC
@daveatsafe thanks for the help. I tried down this route but because not all the rasters started out with the same dimensions it was hard to put together. Instead I just created a full extend raster populated with nodata then the rastermosaic to merge with the original content.
