Enable feature caching between sessions
  • January 16, 2021
  • 145 views
townest
Forum|alt.badge.img+4
Is there a way to enable feature caching between sessions, so that the workspace doesn't need to be re-run after closing Workbench? Thank you.
Tyler
FME Workbench 2020.2.1.0 Win64
Best answer by tomf
Save your workspace as a template (.fmwt) (File > Save as Template...) and include feature caches:
templatethen just open the template the next day. Your caches should be there for you.
tomf
Forum|alt.badge.img+14
  • January 18, 2021
  • January 18, 2021
@townest​  This is when judicious use of collapsed bookmarks is helpful. When you collapse a bookmark, feature caching for all the contents of the bookmark is turned off, so this will significantly improve performance, but also save on disk space when you store your workspace with caches as @tomf​ suggests.
townest
  • January 18, 2021
Thanks @tomf​ and @Mark Stoakes​. If I do use the fmwt what is the best practice for converting back to fmw? Thanks again. Tyler
  • January 18, 2021
@townest​ just open the fmwt in FME Workbench and it'll open the cache files.
