email sent and received but attachment doesn't make it
  • Mar 16, 2018 1:31 AM UTC
  • 52 views
annette2
Forum|alt.badge.img+11
I'm trying to send an email with an attachment where the attachment comes from a shared resource.
$(FME_SHAREDRESOURCE_DATAADA)/Rapporttoattach.xlsx
I'm using this workflow
I receive the email but without the attachment. The shared resource does exist.
Any ideas on how to troubleshoot why the attachment doesn't arrive?
Thanks,
Annette
Forum|alt.badge.img+63
I think that workflow uses the FMEServerEmailGenerator custom transformer. Since then the Emailer has been introduced, have you tried that one?
lau
Forum|alt.badge.img+3
  • Mar 16, 2018 10:27 AM UTC
Hi Annette,
I encountered similar issue few years ago but it was on FME Server 2015. The problem came because of the custom shared resource. They were not initialised when I worked with Controller/Worker workspaces. In the Controller, the macro was initialised but in the worker it remained blank.
If you use a ParameterFetcher followed by a logger can you see if your macro is well set?
