Elegant way of reading AES-encrypted ZIP on server?
  • November 19, 2019
  • 21 views
I am trying to find an elegant way of reading content from an AES-encrypted zip-archive which is downloaded from a trusted source.
If it were not encrypted or just used cryptozip, I would just use a pythoncaller and zipfile and process the results of a httpcaller. However, zipfile within python seems to be unable to deal with aes.
Is there an elegent way around this? Will I have to save the file, run 7zip through a systemcaller and read the contents?
sigtill
Forum|alt.badge.img+25
  • November 19, 2019
7-zip + systemcaller would be the best approach I believe
  • November 19, 2019
Too bad - I had hoped there would have been a nicer way to do it by now.
I'll have to find out the install and utilities folder first then.
