Duplicate feature based on attribute?
  • May 5, 2021 10:17 AM UTC
  • 118 views
aron
Forum|alt.badge.img+16
I would like to duplicate features based on attribute. See following example.
The result I would like to acchive would be a set of new features containing only A, only B and only C. E.g. this would require the geometry1 to be duplicated into one A and one B. To make things more complicated the attributes are dynamic, so matching sets need to be found before duplicating.
Any ideas on how to achieve this?
table2
Best answer by nielsgerrits
AttributeExploder with Keep Geometry = Yes, then test if _attr_value has a value?
nielsgerrits
Forum|alt.badge.img+67
  • May 5, 2021 10:58 AM UTC
Forum|alt.badge.img+54
I'm not 100% sure of the outcome you want here, but I think starting with the AttributeExploder would be the way to go
aron
  • May 5, 2021 11:41 AM UTC
Thanks both of you! That was enough to get me on to the next step.
