Draw perpendicular Lines at Specific Distances
  • Mar 17, 2016 4:57 AM UTC
  • 12 replies
  • 221 views
Hi everyone, I have a large table of points (example) and a straight polyline file. I need to start from Zero metres and travel along Distance (metres) and draw perpendicular lines (negative is left) on either side for Offset (metres)
IDDistanceOffset123-12123956356210473-34
The result should look like this
I tried 2D Vector Generator developed by @takashi but so far I have got only the following
This Line layer has 5 segments has two columns. Only first segment (Start 0 End 1) has worked
The other 4 segments failed with the following error.
StartEnd_failure_reason 23
start index is out of range
IDStartEndA01B12C23D34E45
Anyone can help me please? Thanks in advance.
Best answer by takashi
Hi @thiru, thanks for using the 2DVectorCalculator. How about this?
  • Mar 17, 2016 5:43 AM UTC
  • Mar 18, 2016 7:12 AM UTC
Thank you very much @takashi.
Do I need to divide the original straight line before the featuremerger?
This is the result that I got so far. It's a Friday here, I must be missing something in my brain. Have a good weekend, @takashi
  • Mar 18, 2016 8:25 AM UTC
@thiru, why do you think that you might need to divide the line? In my workspace example, I assumed that the input is just a single straight line, and every "Distance" is measured from the start node (Distance = 0). If the actual data condition is different, naturally different workflow would be necessary. Please clarify the actual condition including the definition of each column - "ID", "Object", "Distance".
  • Mar 21, 2016 2:11 AM UTC
Thanks @takashi for responding to my request.
Here's my workspace 2dvectorgen.fmw I can specify the start and end coordinates and use Creator to generate the line layer. What do I use in FeatureMerger where it asks "Join On"
I was using an existing line layer to feed to requestor. I got confused on using FeatureMerger join on.
ID is a row-id that I have added to sort them from 1 to n
Object is what it is
Distance starting from one end of the line (length = 0)
I do not need to divide the line layer. If I can measure the Distance and mark the Offset lines, that's all is required. Thanks once again.
  • Mar 21, 2016 2:56 AM UTC
@thiru, you can merge every Supplier to each Requestor feature unconditionally with setting an identical constant value (e.g. 1) to the Join On parameter. For example:
  • Mar 21, 2016 4:40 AM UTC
Hi @takashi ok, I now end up with "the number of coordinates is less than 2" error. No features are being created.
_creation_instanceIDObject DistanceOffset _failure_reason
0 1 Fence 66.799999999999997 -107.59999999999999 the number of coordinates is less than 2
02Tree77.799999999999997-172.30000000000001the number of coordinates is less than 2 04Fence126.3-116.3the number of coordinates is less than 2 05Tree198.80000000000001-166the number of coordinates is less than 2 06Tree291.10000000000002-146.5the number of coordinates is less than 2 08Pole375-225.40000000000001the number of coordinates is less than 2
  • Mar 21, 2016 4:53 AM UTC
Connect the Inspector transformer to the FeatureMerger and Snipper and run again, to check if every input feature has a line geometry.
  • Mar 21, 2016 5:08 AM UTC
FeatureMerger Merged outputs one record (first row of Excel), no geometry
FeatureMerger Referenced outputs 11 records
Snipper outputs all 11 records, no geometry.
  • Mar 21, 2016 7:57 AM UTC
Make sure that the Creator outputs a feature containing line geometry, and the "Feature Merge Type" parameter of the FeatureMerger is set to "Attributes Only".
gio
Forum|alt.badge.img+15
  • Mar 21, 2016 3:09 PM UTC
if you built lists, you might find yourself dumping geometry.
USe a geometryextraxctor prior to merging, if thats the case. And replacer after merging.
  • Mar 22, 2016 2:59 AM UTC
Success. Your solution has worked @takashi . The Create did not create the geometry because the co-ordinates that typed have vanished. I retyped them again and it works now.
I am so grateful for your guidance. Thanks.
  • Mar 22, 2016 4:06 AM UTC
Good to hear :-)
I forgot that the 2DVectorCalculator can accept a negative value for the Vector Length parameter. If the specified length value is negative, the direction of the resulting line will be reversed. Therefore, you can omit the Tester and one 2DVectorCalculator in the workspace.
