DBF Writer: DBF file exceeds maximum size of 2 GB
terezia86
HI,
my translation is always unsuccessful due to: DBF Writer: DBF file exceeds maximum size of 2 GB.
yes, it is so big, but I need to translate it and a few files which are even bigger. Shape into shape.
Any ideas?
thanks
Best answer by david_r
The DBF file format, which is used as part of the Shape format specification, is limited to max. 2GB per file.
You may want to consider using a fanout to split the data into several output files.
  • June 12, 2019
terezia86
  • June 12, 2019
Hi @david_r!
thanks for your reply. It has worked.
Just a litte sad, because I need to split into many folders-which I do not need. anyway it helped... thanks
  • June 12, 2019
terezia86 wrote:
Hi @david_r!
Yes, it's unfortunate, but also fairly common with these very old file formats.
Forum|alt.badge.img+58
terezia86 wrote:
Hi @david_r!
Just a quick add-on: you don't need to have the output in different folders, you can also have one folder with separate shapefiles. In that case you need to set the name of the output shapefile featuretype to something that depends on an attribute. It's a bit confusing as it is technically a fanout (what @david_r referred to) but it's not called a fanout anymore.
terezia86
  • June 12, 2019
actualy I do not need to have a separate folders, the separated shapes are also ok. How can I set it?
terezia86 wrote:
You can set the shapefile name (in the feature type properties) to an attribute value. So for every unique attribute value you'll get a new shapefile.
terezia86
  • June 12, 2019
Aah, all right! Thanks a lot!
