DateTimeCalculator claims invalid input for date fields
  • Jan 7, 2026 8:50 PM UTC
  • 6 replies
  • 136 views
aaron
Forum|alt.badge.img+12
I have a workspace where the DateTimeCalculator is failing for all records. The rejection code is always INVALID_INPUT. And yet, when I view the data in Inspector the two input fields I’m using both list as Date under Data Type. The dates look fine fine (e.g. - 20251216). It fails for any mode - Add or Subtract, Calculate Interval, etc. Any ideas why it’s failing and what I need to do to fix it? (FME Form 2025.1.0.0)
Best answer by aaron
I upgraded FME Form to 2025.2.1 (from 2025.1) and rebuilt my workspace. It works!
Forum|alt.badge.img+63
Can you share a screenshot of how you have it set up? I just tried it with that date and it seems to work just fine for me
s.jager
Forum|alt.badge.img+27
  • Jan 8, 2026 8:55 AM UTC
No, that’s limited to the DateTimeConverter, the DateTimeCalculator doesn’t have that issue.
s.jager
  • Jan 8, 2026 11:41 AM UTC
Unless there’s a DateTimeConvertor in front of the DateTimeCalculator that does this, and it’s not noticed earlier. But you’re right, that particular problem does not affect the DateTimeCalculator itself, I missed that bit.
aaron
  • Jan 8, 2026 4:02 PM UTC
​@redgeographics, two screenshots below. One of the workspace and another of a record from the output to the Inspector after the data passes through the DateTimeCalculator.
But I just peeked into the message under fme_expression_warnings and may have found the issue. It looks like the second value in the DateTimeCalculator is not populating. The warning reads, “Failed to evaluate expression '@DateTimeDiff(20251204,,DAYS)'. Result is set to null.” I tried testing again using the same attribute to Calculate Interval between datetimes, which should produce a value of zero (0) and FME throws the same error. That tells me it’s not the data. Bug?
aaron
  • Jan 8, 2026 10:16 PM UTC
