DateTimeConverter has format of @Value(attribute) if chosen from the Attribute Value pick list vs the 3 dots window and then fails to convert value.
  • Jan 24, 2023 11:20 PM UTC
  • 7 replies
  • 223 views
jakethepainter
Forum|alt.badge.img+7
Has anyone else experienced this? I'm using FME 2022.2. If I pick an attribute from the arrow drop down menu, it inserts it in the DateTime Attributes field as @Value(CREATETIMESTAMP). When the transformer runs, it doesn't convert the value.DateTimeConverter with weird attribute value using @Value But if I select the attribute from the 3 dots menu, it's fine
DateTimeConverter value selected from 3 dots menuIn the 3 dots menu chooser, there are sort of two sets of the attributes....
list of attributes plus list of @Value(attributes)
Forum|alt.badge.img+63
I've come across this as well recently, FME 2022.2 just like you
Forum|alt.badge.img+54
  • Jan 25, 2023 10:29 AM UTC
@jakethepainter​ This is a common pitfall in the DataTimeConverter GUI that others have encountered. We've changed the GUI slightly in FME 2023 so that, hopefully, users are less likely to select the wrong option. The AttributeValue option is there so you can have a more dynamic DateTime conversion. Using something like @Value(dateList) allows you to dynamically set the value of dataList = date1 date2
ferhdfme
Forum|alt.badge.img+15
  • Dec 17, 2025 3:59 PM UTC
I think that even in the latest version (2025.2) it is still quite confusing to choose between @value() and the attribute. As possible improvements, the error message could be more descriptive, a new section about this case could be added to the transformer help, or the GUI could be improved.
s.jager
Forum|alt.badge.img+27
  • Dec 18, 2025 11:46 AM UTC
I’m constantly tripping over this one, wondering why the hell my datetime’s got rejected when I can see there’s good values in there, and sometimes even right after a DateTimeStamper. I would prefer the GUI be restored to simply using attribute values, since I’d never use “a more dynamic DateTime conversion”. It feels like a bug to me (FME 2025.1).
crystalatsafe
Forum|alt.badge.img+32
Hi ​@ferhdfme and ​@s.jager
Thank you for sharing the confusion around this.
I have submitted a ticket to our development team (internal reference: FMEENGINE-89042), hopefully we can make some improvements to the GUI and/or improve the error messaging. I will make sure to keep you updated on the progress.
crystalatsafe
Thank you again for sharing your thoughts on the confusion around this.
We have improved the error messaging in 2026.1 which was released today: safe.com/downloads/. We are still looking at some changes we can make to the transformer.
