DateFormat showing as null in AttributeCreator step
  • Nov 27, 2019 8:33 AM UTC
  • 5 replies
  • 83 views
I am passing a date UserParameter into a workbench and am then trying to convert it from the standard FME format to dd/mm/yyyy
Parameter is formatted as yyyy-mm-dd and if I just use the Parameter the value unformatted
it outputs as yyyyddmm eg 1950-01-01 becomes 19500101
I want it to output in dd/mm/yyyy format but if use dateformat($(PositionEffective).%d/%m/%y) a null is returned.
Thanks in advance
Forum|alt.badge.img+54
  • Nov 27, 2019 8:51 AM UTC
Are you on a older version of FME?  Should be DateTimeFormat with capital Y if you want 1950
@DateTimeFormat($(date),%d/%m/%Y)
  • Nov 27, 2019 8:52 AM UTC
You might have to force it with a DateTimeConverter after the AttributeCreator.
sipsysigh
Forum|alt.badge.img+12
  • Nov 27, 2019 9:21 AM UTC
Hi @left65,
As @ebygomm mentions, it looks like you got the syntax slightly wrong.
Instead of:
in your example, it should be:
@DateTimeFormat($(PositionEffective),%d/%m/%Y)
You can use this function directly within the AttributeCreator, like this:
Edited to actually include the screenshot! Not sure what happened there...
Hope this helps.
Si
Hi @left65
if the date comes in yyyy-mm-dd format (i.e. not in FME date format), it needs to be parsed first. You can use
@DateTimeFormat(@DateTimeParse(@Value(_date),%Y-%m-%d),%d/%m/%Y
expression to parse and then format your date. There is also DateTimeConverter transformer that will help you avoid writing nested functions :)
  • Nov 27, 2019 6:33 PM UTC
Hi @left65
My version of FME will format from yyyy-mm-dd without parsing first.
Incidentally, i think in this case it's a date parameter that is displayed as yyyy-mm-dd when you selected but is actually stored as an FME date.
