CSAR band missing from components when reading to FME
  • September 18, 2018
  • 14 views
Hi!
I am having a following problem while reading CSAR -file into FME Desktop 2017:
CSAR point cloud file contains a Status band. However, the band is not visible in components list when reading the CSAR point cloud file to FME, although other bands can be found from the components.
jovitaatsafe
Forum|alt.badge.img+11
Hi @jsafme,
Are you using the CARIS Spatial Archive (CSAR) Point Cloud Reader? If you are and the status component is still missing, can you confirm that the component type is one of the accepted ones from this doc?
  • October 9, 2018
Hi @JovitaAtSafe.
I am using the CARIS Spatial Archive (CSAR) Point Cloud Reader. The component type seems to fall into type ANY, but isn't still accepted by FME. According to CARIS the Status band cannot be exposed.
