creating svg file fom dxf
  • March 24, 2017
  • 161 views
femo
this topic is not new for this Forum. Nevertheless I need your support.
I have understood that svg has got a XML-structure. I have also understood, I think, that i don't have to bother about crating the tags since this is accomplished by the svg-writer itself.
The svg-file, viewed with an editor, I have created so far looks like this:
I need to manipulate the stroke-width parameter (higklighted in the screenshot) by means of FME. Unfortunately I cant find the respective parameter among the various svg-writer parameters.
Do you have an idea?
  • March 24, 2017
itay
Forum|alt.badge.img+19
  • March 24, 2017
You could read the xml as text and use a regex to extract the stroke-width value for manipulation.
gio
Forum|alt.badge.img+15
  • March 24, 2017
@femo
You can directly wite these attribute to your svg writer just like they look in the xml editor of the likes of iInkscape:
This is from a attribute creator in a svg creating workbench of mine.
(this is how Inkscape consumes it)
svg_style
fill:@Value(ColorHtml);fill-opacity:1;stroke:#000000;stroke-width:2;stroke-linejoin:round;stroke-miterlimit:4;stroke-opacity:0.96744187000000004;stroke-dasharray:none
femo
  • March 31, 2017
@itay sounds smart to me. Especially because I want to Keep the Parameter variable in order to manipulate them in QGIS. I forgot to mention that.
The following snippet:
<svg xmlns="http://www.w3.org/2000/svg" viewBox="-0.9375 -0.9375 76.875 93.5"><g fill="param(fill) #fff" stroke="param(outline) #000" stroke-width="param(outline-width) 3" transform="translate(0,91.625) scale(1, -1)">
enables the user to key in the desired Parameters in QGIS.
@david_r and @gio: thank you to!
